One of these days I'm going to get around to getting my car running right! I haven't had the urge to mess with it much lately, but I think I'm starting to get some energy back. So...
I've a got a weird BLM thing going on. Cells 0 and 15 (idle and WOT) are both pegged at 160. All the other cells in the BLM table look pretty good. Does this ring any bells with anyone for a potential cause?
Car seems to drive okay for the most part, although I get a little detonation earlier than I'd like, around 14-15 psi. Doesn't smell really rich at idle (at least not that I've noticed), haven't noticed any billowing black clouds of smoke at WOT either (but then I'm not usually looking in my rearview mirror while flooring it). The inside of the exhaust does tend to be a bit sooty however.
Tried two different chips, exact same thing with both. One chip is Jay's, about 4 or 5 years old by now I guess, the other is from a nameless member of this board who kindly sent me a chip file that he had spent many hours dialing in on his car for these red stripe injectors. Now that I think about it, I did at one time have a semi-experimental Thrasher for red stripes, and it always read really lean at idle, even after Scott added a bunch of fuel to it for me. I had to really crank up the fuel pressure to get some decent idle O2 readings. This was... 3 or 4 years ago I guess.
I do have some oil showing up in the intake. I don't have that many miles on this rebuild, and I have found oil on the top of my Power Plate after not very many miles. The up pipe and throttle body is dry as a bone, so I'm thinking it is getting sucked in through the PCV. I do have a stock valley pan in there. I've wondered about a leaking intake gasket (I do have ported heads BTW), but I put a vac gauge on it and it was pretty steady. Thought it would be pulsing if I had that particular problem. How else could I diagnose that? Would an intake gasket leak possibly cause this BLM behavior?
Exhaust system could easily have a leak, the exhaust ports have been opened up within an inch of their lives, and I would not be surprised at all to find a leak there. Don't hear anything, but haven't closely investigated either. Could an exhaust leak cause such weird BLMs?
Oh yeah, I also did Bruce's MAF relocation project a while back, put the MAF right on the throttle body. Had to move it back due to hood insulation pad interferance, but before I did I checked the BLMs again, and there was no change at all. So the BLM problem is not due to an air leak upstream of the throttle body.
Combo - rebuilt shortblock, 206/206 cam, ported heads, TE-60, red stripes, Translator+, I guess that's the highlights.
If anyone has any good ideas, let me hear them!
John Estill
John Estill
