JadeMonkeyStang
TRs on the Brain
- May 25, 2001
Whenever I hit the gas from idle, even just slowly leaving a stop light, my car hesitates for a second and then will go. Seems to run fine otherwise (running a little rich I know). The car almost feels like it dies completely when you press the pedal and then it basically wakes up, realizes it should be moving, and takes off just fine. Does this from light/easy throttle or from just mashing the gas. If the car is anywhere above idle I don't notice the hesitation. I had the car at Dynotech a little while ago (for a checkup, not for tuning or anything) and was told that everything checked out and that it was running well. Any tips or advice would be great.
-Jade
-Jade
