Just installed 2004r last weekend. Mostly around town driving all week, some highway but only a
couple miles and usually in the evening. Trans temp never went above 180* (averaged 170*),
eng coolant temp averaged 180*-190*.
I took it for a trip today (late morning, outside temp about 80*-85*) and after about 10 miles on
the freeway going 65-70mph eng coolant temp came up to 195*-200* and TRANS TEMP came up
to 210* and climbing (in 4th with conv l/u). I pulled over and let it cool down to below 180*,
got back on the freeway and within 2 miles it was back up to 210*. Again I pulled over and cooled
it down to 170*, drove back home using side streets, coolant temp stayed below 185* and TRANS
TEMP stayed below 180*.
I am running an ext cooler in front of radiator used after rad cooler. My TH350 I just took out never
went over 180* even on the freeway averaging 65-75mph @ 3500rpm.
I'm thinking my trans cooling set up may not be enough for the 2004r as opposed to the
TH350 being the 350 has a 2400 stall conv and the 2004r has a 3000 stall l/u conv, yet I was
hwy driving with it locked up so I don't think it's a stall slippage issue.
Need some direction here, all suggestions welcome, Thanks! :smile:
Car Info:
'64 Chevelle 383ci, 3.73 rear posi, 2004r just rebuilt using Ck manual, billet fwd drum,dual fed,
current Ck shift kit, 3k l/u conv, ArtC deep pan w/700 filter, trans pressures great, shifts
firm (2-3 little harsh :wink
____________________________________
Jim
Car Info:
Jim
