the last time i drove the car i noticed that the shifter moved hard going out of park into drive. i figured it was a prob with the cable. i was heading to work and it was light out. on the way home from work, it is now dark as i work overnights, the shifter was still hard and i noticed that my reverse lights were still on while in drive. i played with the shifter for a bit in the driveway and also heard a strange. i remebered that the neutral safety and reverse light switch is under the dash along the steering column. my question is, am i looking at an adjustment issue or a replacement. assuming that my assumptions are correct in the first place.
