Anyone can make all the assumptions they want, but without having any experience in trying it, all they are spouting is opinion.
Depending on car, the differences may or may not be a big change, it's about how close the intial state of tune is. But, by using the Translator, and the late MAF, it then allows you to move the IAT sensor into the Plenum, and use it as a MAT sensor. Then in populating the IAT/MAT timing correction, you will allow the engine/car to be more consistant in it's performance. Just thinking about that for a moment should allow you to see the difference in how the more accurate the tune, with more valid corrections, the better the car will run. Look back to the Apr, and Oct Tech area, and look for threads about lose of performance or detonation. Why?, the that's when the fuel manufacurers change brews and the temps change enough that the stock calibrations, go out to lunch.
While some folks like to brag about a certain mod being worth .X amount, I don't since there are too many variables to make any claim that would be universally true. But in this thread 2 experimenters tried it, and both picked up 1 PSI. So there is something going on.
