Just got motor back in after a new piston. Fired up and you could hear lifters a little and they quieted, then looked at auto meter electrical oil pressure gauge and it didn't move. I might have ran it 10 seconds. I did prime oil pump with drill in cam sensor and the drill bogged down and felt like it primed. I checked my wires and it all seems good. I cut one and hit it with a quick 12 volts and the gauge would move to the negative side. I did unhook my turbo line and fired it again and it shots a solid stream out. So I'm sure it's my gauge. How do I check it? It worked fine before I pulled motor. My idiot light does come on when you turn ignition and comes off when motor runs.
