BoOsT-CrAzY
- May 28, 2007
Hey guys i am new here and need some help if possible please i have an 86 with a big front mount and i cant keep it running cool it run about 200 - 210 on the freeway please help
Doesn't matter if the radiator "looks" like it flows good, your car is running 200+, obviously it's not doing a good job.
If that list of mods is the only things you have done to your car then it sounds like you don't need a "huge front mount" in the first place. Don't slap on a front mount intercooler if you expect to be cruising around town with the temp at 170.
Either go back to a stock location intercooler or you'll have to consider buying a different radiator, dual fans, etc. One cheap "fix" is to hotwire the stock fan so it runs on high speed instead of low. But that's not really a solution to the problem.
