Please help with IDing this green wire/connector, I was looking around after pulling the MAF pipe off and found this laying on the water pump cover. Tested it with voltmeter and got 12.4V with key on, it looks a little melted too.
thank you.
Could be wrong, but I think it might go to one of the sensors on the intake manifold. Has a small tab that the connector you showed slides onto. I have seen some intake manifolds that dont have that sensor though.
Thanks Guys, found it. A previous owner removed the overtemp switch (caspers has great pictures) and attached a sending unit for an aftermarket temp gauge. From what I can see the overtemp switch just sets the idiot light for overheating and does not send a signal to the ecm?
