looks like the brake light switch... goes to the proportioning valve/distribution block mounted on the frame rail... just follow the brake lines down from the master cylinder and you will find it..
Fixed the fuel pump by disconnecting that black plug and connecting the green plug as shown.. still need help on the first picture.. Don't remember where that plug goes to??
That's no good disconnecting them and leaving them unplugged.. good thing I have a spare ecm if it fried it.. if the ecm is fried the car won't start right?
Yes a dead ecm can cause a no start. Key on Engine off if the check engine light comes on the ECM is at least getting power. I have seen a bad ECM cause the fuel pump to run continously
