I converted to vacuum from the PM early this year and since then I can't stop the car. It's easier to stop a '48 Peterbilt. I can stand on the brakes and the car slows to a stop. There's no way to get them to lock up. I can't figure out what's wrong. I've got a used booster and pedal (81 Regal) with a new master cyl. and I've bought 2 new check valves for the booster. The booster holds as much vacuum as my 98 GTP. I've got a billet TTA vacuum block on the plenum. I've bled the system 3 times over 500 miles, and I bench bled the master cyl on the car (cracked the lines at the cyl).
Any guesses what to try next. I really don't want to put the PM back on and buy an accumulator to get this pig to work.
Thanks in advance,
Mont Hunt
87 GN
Thanks in advance,
Mont Hunt
87 GN
