My my water temp is anywhere from 65 to 100 degrees my tip in is lean. The cars perfect in tip in over 100 degrees. The cars also perfect at idle warmup from the same 65 to 100 degrees. Would the adjustment be AE Fuel verus CTS? I was worried that if I gave it the adjustment it needed in AE fuel verus CTS it would then idle too fat. I have a sequential unit, and it seems to be very sensitive to burn the plugs too rich at idle during cold and warm setings.
