I have a stage 2 block that has a good portion of the DS pan rail busted and gone from a rod failure. Otherwise it a pretty good block so its worth trying to save!! Odell tells me he knows a shop here in Ohio that can repair it if I come up with a 14 bolt block that I can remove part of the pan rail required to fill in the void.
Anyone have a junk block that has a good drivers side pan rail that I can have/buy??? I am not sure if a 20 bolt block would work or not?? I think it would require a 14 bolt donor block. Any help appreciated Mike
