Sounds like the oil feed hole was not drilled. Like Cal stated. If you run a solid roller cam, it isn't needed except to oil the rockers. You can externally feed the rockershafts, though, and not have to COMPLETELY disassemble your engine and drill it, clean it and re-install the cam bearing. I would go external feed and be done with it. Hollow shaft, and oil feed through the head. Use a -4AN and pull oil off the front of the block next to the oil inlet. There is a 1/8 pipe hole there, just for this purpose. (StageII on center block, if not, install a Tee somewhere) Hope this helps. Kinda funky, but it will work. If you have a hydraulic roller cam, then it will NOT work. They need oil pumped through them. The lifter bores need to be drilled too, if you have a hydraulic roller.
That oil feed transfere hole is real easy to miss/forget. I almost did on the first StageII I built many years ago. I caught it when spraying brake clean through all oil holes and blowing them out just prior to assembly. It was puddling in the cam bearing journal. And I thought, Geeze...why is it doing THAT???? Then I looked, and 'bout passed out. Glad I caught it. Whew!
