Help needed on brakes!
85zoom
Hi gang. A fellow GN driver needs some assistance on his powermaster brake system. It's leaking and he cannot drive the car. It's a white 87 and his name is Roy. I drive a HotAir so I am not familiar with the powermaster. Those of you who are.......could you please give Roy a call, 368-6182, and help our brakeless brother out?! Thanks, gang. :D :D :D
you gotta replace the powermaster motor. it happened to me on my friends gn, and it leaked onto the header and started a fire. try to replace it asap, or you can swap it over to a vacuum brake system.
Go to GNTtype.org..... there is a troubleshooting diagram there to find the problem. If it were me, I'd convert already.
Jackson, thanks for stepping up and calling Roy. Knowing we can call others for advice goes a long way and helps raise the confidence level in attempting to repair our own GN's. Big Mahalos ! :D
