FattyMcTrickle
- Jan 27, 2005
So I am pretty stumped, heres my situation.
The car misses like crazy at idle and will die when given gas. Here's the whole story.
The car has been sitting for about three months now as I've been slowly working on it. It ran like a top before I parked it.
Here's my setup.
Stock Motor/Heads
Stock Intake, Doghouse, Throttle Body
GT6152S Turbo
Spearco Stock location intercooler
60LBS Montrons
Walbo 340 Fuel pump with oldschool hotwire
LS1 3.5in MAF with translator
Accufab Adj fuel pressure regulator
Fuel Pressure guage on the rail
Full Throttle Speed Extender Extreme Chip
So at idle the car misses like mad the plugs and wires were working fine when it was parked so I'm weary to suspect them. I have gone over all the vacuum lines and they are all new or in great shape. I am 95% sure the problem is with fuel delivery as the car is running absolutely pig rich and blow's soot like an untuned Mitsu Evolution and I cannot get the fuel pressure to sit stable (guage needle jumps) or get it to go below 48PSI. With the regulator adjusted all the way out it is still at 48 with the vacuum line on or off. I put the stock fuel pressure regulator back on and the pressure still stayed at 48 with the vacuum line on or off and still jumped around. But it misses so bad it barely pulls any vacuum so I'm not sure if that is relevant. Also some food for thought I have eliminated the charcol canister and just have the line from the fuel tank hanging.
My next step is to get some brake clean and spray around looking for vacuum leaks and get some scanmaster readings to post up.
Here's my setup.
Stock Motor/Heads
GT6152S Turbo
60LBS Montrons
