Year: 1985
Make: Buick
Model: T-Type
Been working on a neglected car and have a part that was zip tied to an AC line on the passenger side. It has a couple tabs on the side that might have once allowed it to mount above the fender wall but not sure. Part seems mostly hollow with a couple vacuum lines running to it.
I also have several electrical connections on both sides of the car that are not hooked up to anything. The car does have a vacuum brake conversion so not sure if some of the connections go to the original PM system.
The car was driven 3+ hours from Detroit to Cleveland when purchased and pulled a bit of DD duty when I got it home. So it was running okay'ish given the level of neglect by the PO.
Here is a short vid of the parts, any help is appreciated:
Link for the embedded challenged.
Make: Buick
Model: T-Type
