I have been doing a bulid up on my original owner 1986 GN over the last year.
I have done all the work my self except the trans swap.
My combo is this:
Stock block and heads, valve covers never been off.
CPT65
50# inj
LT-1 MAF
precision front mount
Aluminum RAD w/ ramcharger fans
reds XP pump + adj FPR
Trans +
Extender or sometimes Turtbo tweak Alchy chips
Razor's progressive ALKY KIT
New timing set
PTS Extreme Strip/Street Trans
9X11 3000 converter.
autolite 24 plugs gapped at 30 (10 miles on them)
New GM Coli pack and Ignition module ( installed today)
JW Wheel SFI lightwheight Flexplate
RJC Billlet Pully set.
Here is my last hurddle and I have had a few.
I took the car to the track Sunday and Ran 7.7 's @ 92.5 MPH backfiring in the exhaust down the track with 25# of boost.
The back fire is consistant with anything over 20 lbs of boost.
Under 20 # no backfire.
I replaced the fuel filter, plugs, coil pack and ignition module (both GM) today trying to figure out what is going on.
Same problem. BOOM! sounds like a stick of dynamite under the car and black smoke bomb too.
I am running out of ideas and I am so close to having a damn fine running GN that all of us can be proud of.
I need your help.
Thanks,
Rich
My combo is this:
CPT65
50# inj
LT-1 MAF
Trans +
New timing set
I need your help.
Thanks,
Rich
