Firechicken
- Jul 23, 2003
Hey guys, I decided to install a TCI clone (I copied the TCI sep plate holes into the trans sep plate and used the pressure reg spring and line bias block rod from the TCI kit) shiftkit today in my driveway. What a pain. Anyway, after bolting the valvebody back in place, in the bottom of my drain pan was a pin that looks just like the 3-4 accumulator piston pin. I thought the pin might have dropped out while I was getting the valvebody ready, so I went ahead and took it all apart again, only to find out that the pin is where it should be.
So I checked the 1-2 accumulator, and its pin is in place as well. Where did this pin from hell come from? I have gone through the ATSG book and can't find a diagram showing an "accumulator style" pin anywhere!
Please help, I want to put this thing back together again in the morning.
Thanks in advance
Thanks in advance
