Originally posted by Not Avg 6
Tow Man,
I was in the the same situtation as you, I ran 113 on BFGDR's last year. Wanted to do heads and cam and it came down to a $400 difference on the price from my vendor between the Champion alum and iron. Did alot of research and mine changing back and forth. Decided to go with the alum's and Cometic head gaskets. The car will be back running this week and I'll know more soon. Feel real good about my decision though.
Originally posted by Tow Man
My only concern with aluminum on iron is leakage and reliability. Not that my car is a daily driver, but I like to be able to jump in it and go anywhere without too many worries.
Standard run of the mill cars not pushing 30 PSI of boost or high cylinder pressures with 8 head bolts I would expect no less. Most guys trying to approach the amount of boost required to run low 10's or 9's seem to have better luck with irons not lifting the heads due to rigidity. The aluminums have more give and will lift under less boost from what I have seen on here. The result is head gasket problems. Since the new 2nd generation GN-1's seem to have fixed the cracking problem that isn't much of an issue. I don't know about the guide problem as it hasn't cropped up much lately either.Originally posted by bsdlinux
Aluminum heads are one of the best upgrades you can do to a engine. You know we are not talking about the Cosworth Vega crap of the 70s, where melt downs were common.
Almost all new engines have aluminum heads. My 1997 Mailbu has aluminum heads on an iron block. We always hear that GM did most things right when they built our cars. What makes anyone think that they are not now, with all if the aluminum headed engines running around with 200,000 miles on them. Hell even the trucks come with them now!!
Many friends of mine have aluminum heads on iron SBC engines. There are no problems if you use the right head gaskets and verify that your deck is straight.
Driveability issues, I don't see where this is going to be a problem. Just the fact that the heads are aluminum make the engine respond better in general and to mods.
I have no idea where all of these bad aluminum head stories come from. Back in the 70's and 80's I could see it, but now the tooling and production quality of these heads are much better. How many sets of Edlebrock aluminum heads are out there on daily drivers.
I doubt we see any more aluminum head failures than cam failures, etc where common mistakes can be made.
These Buick engines respond very well with the aluminum heads. I will eventually go with aluminum as well. Right now I have ported irons which perform quite well.
Off the BOX now....
I got the car running with the new combo!
This head and cam package is the BIGGEST seat of the pants improve that I've ever done to my GN. Street mode (15-17psi w/93 octane) feels like race mode (25psi w/112oct) with the stock long block from last year's combo. It's very impressive.
Originally posted by talstar
I'm in the process of installing gn1s on my car right now. I put about 100 miles a week on the car at least. I will let you know how they hold up.
