-----------------------------------subsolar0 said:Just wonder how big of a cam I can go with and not have to worry about CA smog. And are there any aftermarket heads that will pass or should I stick with ported stockers? Will roller rockers pass smog?
-------------------------------Hacksaw said:Aftermarket heads may get you into trouble, especially if they're easy to distinguish from stock. It's not just passing the idle/dyno tests, but also passing visual inspection. Unless an aftermarket part is on the Executive Order, it's not allowed.
Yes, there are some things allowed aftermarket without an EO, but I'm pretty sure heads need an EO.,
------------------------------subsolar0 said:Alright, so if I just port the stock heads, how big of a cam should I go with to not have to worry about CA emissions?
Wells said:Maybe if you E-mail Joe Cheung at:
-------------JSAautomotive said:What does Joe Cheung do at BAR?? Whats his title??
