Is the headlight switch supposed to be illuminated (and the dash light dimmer switch)? If they are, can I disassemble the switch and clean the internals to get it working again or do I need a new one?
Thanks. That is what I assumed since I just disassembled the switch and did not see a bulb. That sure doesn't make a lot of sense for them to be non-illuminated.
Ha Ha, you are correct. But, if I get in the car at night and close the door (no lights on anywhere) the switch isn't noticeable. I guess it should illuminate if the key is turned on or the engine is running. That would make more sense.
