G greezy 396 New Member Joined Dec 28, 2008 Jan 4, 2009 #1 what is the best head gasketto run a mid 11's car
T "Turbo-T" V6 on steroids Joined Jan 10, 2007 Jan 4, 2009 #2 The kind that's not blown. :wink: Which is the kind that's not seen detonation.
A Audie1 Hooah! Joined Dec 27, 2008 Jan 4, 2009 #3 87Regal3.8SFI said: The kind that's not blown. :wink: Which is the kind that's not seen detonation. Click to expand... :biggrin: :biggrin: :biggrin: GM stock head gaskets would be just fine for what you are wanting.
T turbojd Well-Known Member Joined Dec 27, 2005 Jan 4, 2009 #4 Audie1 said: :biggrin: :biggrin: :biggrin: GM stock head gaskets would be just fine for what you are wanting. Click to expand... X2:biggrin:
U Underboost Mr. Dull Joined Oct 4, 2005 Jan 4, 2009 #6 With a 20 over bore the RJC HG's work great I have never blown one. If you have a bigger bore than 20 and run boost @ 25+lbs get Cometics. Stock Gaskets will blow at 25psi with the slightest knock. Just an FYI
G greezy 396 New Member Joined Dec 28, 2008 Jan 4, 2009 #7 thanks preciate the help, cometics gaskets, would studs be better than bolts when i put it bak together??
U Underboost Mr. Dull Joined Oct 4, 2005 Jan 4, 2009 #8 greezy 396 said: thanks preciate the help, cometics gaskets, would studs be better than bolts when i put it bak together?? Click to expand... If you want mid 11's your good with ARP Bolts. If you decide on studs make sure you get the alan key type so you can pull the head on the pass side.
T turbocam Member Joined Jan 28, 2006 Jan 4, 2009 #9 I run Fel Pro 9441pt head gaskets and arp studs.I run 11.0s with no problems.
U Underboost Mr. Dull Joined Oct 4, 2005 Jan 4, 2009 #10 turbocam said: I run Fel Pro 9441pt head gaskets and arp studs.I run 11.0s with no problems. Click to expand... One of the main reasons why I don't like the FP's is once you blow the gasket the graphite goes everywhere inside the motor, oil pick up etc.
2 27Skulls Member Joined Feb 19, 2007 Jan 4, 2009 #11 Underboost said: With a 20 over bore the RJC HG's work great I have never blown one. If you have a bigger bore than 20 and run boost @ 25+lbs get Cometics. Stock Gaskets will blow at 25psi with the slightest knock. Just an FYI Click to expand... Noticed an auction on e-bay for the Cometics. Do they usually sell for around $125.00 per set?
