Head gasket and bolt recommendation please
87LtdT
Engine is out...going back up with ported irons.
Would appreciate expert opinions on which gaskets to use and which head bolts.
Plus an tips or watchouts.
Any other things I should do while engine is out??
Thanks, Bob Kolhouse
I'd use factory gaskets and TTY factory heads bolts. I've had good luck with these up to 28 psi boost.
Dave
Cometic Multilayer spring steel and ARP 190,000 at 85 ft lbs. Do it once and go race.
Mitch
TURBO DAVE
HEY DAVE HOW WELL HAVE STOCK GASKETS LASTED FOR YOU?
I MEAN BOOST AND HOW MANY PASS'S.
ALSO THE BOLTS WHERE THEY GM STOCK TORQUE/YEILD OR ARP?
I personally use stocker gaskets and ARP bolts. Remmember a good sealer for the threads and oil under the bolt head and washer. This works really good. I am however interested in these new multi layered steel gaskets. Any body try these with oringed heads yet?
