I've posted my problem elsewhere, but with the recent discovery, am posting a new thread. A recap first:
Attempted a poor man's ground wire upgrade to my DW301 hotwired fuel pump. 10-gauge wire to the FP ground wire near the tank, grounded to the alternator housing. Go for a WOT run, and something goes wrong; motor runs like poop as boost developed. Also noticed just then that SM volts reading, which are normally 13.6-13.9, jumped to 14.5-15. Eventually discover the reason it's running poorly is that the GEN II Translator isn't getting power. Malfunction codes, 23 & 34 (MAT & MAF). Today, I discovered that the reason the GEN II isn't powering up is it's ground wire isn't doing it's job. I've checked all fuses; all good. Yes, I disconnected the FP ground wiring...no effect. Have reset ECM twice as well.
The ground wire to GEN II connector is coming from the MAF ground wire. So far, I've determined that there's no ground at the stock wiring to the MAF. That wire goes into a larger bundle of the wiring harness, heading back behind the motor.
Not sure what to do next.
