B bosted86 Member Joined Mar 21, 2005 Jul 24, 2008 #1 is there a groove around the combustion chambers on stock heads? thanks
B bosted86 Member Joined Mar 21, 2005 Jul 24, 2008 #3 I Have A Set Of Ported Heads With Groove In It. O-ring? Can I Use Them Or Does The Block Have To Be Grooved Also?
G gossamer Member Joined Nov 28, 2007 Jul 24, 2008 #4 It sounds like your heads were cut for o-rings. Your block does not need to be cut. Just run lock-wire head gaskets and you're good to go.
