Sorry so long, but I need help and I copied for my thread from another area. Hopefully someone here can help.
I have been fighting these issues for a long time with no resolve.
No smoke at startup or idle. Light very faint white smoke if I give it gas. More smoke of course under boost. Not coming up in boost more than a couple of pounds. If I hold the accelerator at 2k, the rpms fluctuate up and down.
I thought that it might be the turbo, so I bought a new one. Thought that it might be the Max Effort, so I swapped for a Turbo Tweak chip. Yeah it does have a small oil leak in the normal spot, but oil pressure and levels have always been fine. New injectors, same size as posted. I have checked the compression before and there is little to no difference between cylinders. New fuel filter in the external fuel system as posted. Going through a divorce and really don’t want to sell if I can help it, but it hasn’t ran right in a long time.
When I say swapped, I mean I bought directly from Turbo Tweak. I have tried a couple different chips in the Max Effort before getting rid of it.
i have had this car for years, but i know how I explain it might be different that someone that knows more than me to see it. Because of the situation, I don’t have a lot of money to waste at shops. Plus, I have heard stories about people taking their GN to shops that say that have worked on them before.
Anyone else have any idea? What is the chance of it being a small intake or head gasket leak? Would that cause a flux in power and smoke only under acceleration?
Ok, the start of a new week. Never did the tear down. I think that i found a vacuum leak on the adj boost controller line, but still have the smoke. Someone told me to pull the valve cover to see if I have a wiped cam. Could that cause the white smoke? Any other suggestions this morning would help me out.
White smoke is coming from exhaust. Maybe just a little at idle, but a lot more on acceleration. I haven’t been able to take it down the road in a long time. So how much coolant would it really use in the carport.
Ok, spark plugs on 3 and 6 look like brand new, all the rest look like the one in the attached photo
