turbojitsu85
- Aug 23, 2002
1985 Buick GN with 87 drivetrain
88k miles needs paint
asking $16,500 located in La Grange Park, IL
•Fast Xfi w/Caspers harness
(car tuned by Cal Hartline. Hartline Performance)
•72.5 lb hr injectors
•Caspers volt booster coil pack harness
•Ported polished heads with 5 angle valve job (flow and build sheet available)
•ARP head bolts
•Ported polished intake to match heads
•ARP intake bolts
•62mm throttle body ported plenum
•Stock intercooler with duttweiler neck
•Oil Pressure Booster Plate
•High Flow Water Pump
•Precision 6262E dual ball bearing turbo
•4" air intake pipe w/K&N Air Filter
•G body 3" single shot exhaust w/Borla muffler
•GN 1 performance down pipe with external waste gate
•Stock short block freshened up 10,000 miles ago (honed cylinder walls/new rings/new bearings/ARP main studs)
•Double roller timing chain
•210/215 hydraulic roller cam Comp Cam
•Comp Cam hydraulic lifters
•H&R Motor Mounts
•Fbody radiator
•Walbro 340 fuel pump w/Caspers hotwire kit
•VDO Gauges oil/water/boost
•Caspers knock gauge.
•Auto meter Fuel pressure gauge
•Brand new slotted, drilled rotors and calipers
•Brand new vacuum boost brakes
•Jimmy's Trans J-200 4R SS freshly built 2800 stall convertor w/Hayden Trans cooler
•275/50/15 Mickey Thompson drag radials
•KYB shocks
•Extreme Engineering Polyurethane Body Bushing kit
•Moog Springs 1"lower in front stock rears
•Rear Airbags
•Valvoline VR1 racing oil
•ARP head bolts
•ARP intake bolts
•H&R Motor Mounts
•Fbody radiator
•KYB shocks
•Rear Airbags
