Ok, well got to tinker with the car a little bit and do some deep looking at this engine. OK try to describe this the best I can. Coming off what I believe is the turbo housing and running horizontal to the valve covers inner edge and just above manifold height is an arm or bracket with two 1/2" or so holes about 2 or 3in apart that like up with two other holes or another bracket the nuts for the bolts are actually pre welded to the bracket to just screw a bolt in. It looks like both have been missing for awhile judging by the rust coloration matches that of its surrounding area. Are these for another option or what?
There are also two coolant lines that are plugged. I believe both are the the middle two of the 5 T hose cluster that sits to the rear of the manifold.
I also was wondering if anyone knew the bolt size for the adapter plate as my AC Delco adapter plate didnt come with any bolts or attachments.
OK sorry about being pain. Back to my reading diagrams till I figure it out.:biggrin:
