what fan are you using? I would say have the shroud flat up against the radiator or otherwise negate even having a shroud. The purpose is to draw air through the area of the shroud, and not just the area of the fan blades. Otherwise, all it would accomplish is swirling air around in the engine bay. But obviously make sure the fan blade itself won't come in contact w/ the core. HTH..good luck
This gap is normal. I have every bit of that on mine cools fine!! If your using the stock fan it should bolt right up to the bracket on the bottom and to the radiator hold down plate on the top.
It didn't seem that he had a very modified car that would be putting that much more strain on the tranny. And he DOES have airflow, thats the purpose of the fan, and also the purpose of mounting the coolers basically airtight to the radiator core. I was always under the impression that coolers with integrated fans were primarily for people that wanted to remote mount a cooler, be it for space constraints or whatever. Also leads me to wonder why they would even sell coolers w/o fans if they didn't work, because I'm using one on a 700 hp BBC Regal, that I drive to work everyday, and I built this tranny 4 yrs ago, and also on a 1000hp S2 GN, no problems for me....but I guess everyone has their own opinion
External coolers with no fans are worth it in conjunction with the radiator cooler. I just don't like the external by iteslf without a dedicated fan. I ran mine that way with the cooler 1/2" from the radiator, in front of the fan and in slow stop and go traffic temps would creep up to 210 degrees and higher. This was driving it nicely. Once moving it would go down to 180. The radiator cooler keeps things cool when not moving and the external backs it up with additional cooling when you have airflow. It's not an opinion, it's an observation from someone that has tried both.
Opinion: 1 a: a view, judgment, or appraisal formed in the mind about a particular matter b
I stated my opinion, how can you tell me its not right or not an opinion? I've also tried both, on customer cars as well, and in my opinion...yeah theres that word again, it is not necessary for the average car. Yeah if your extra picky, and like to spend extra money for your peace of mind, then yeah go for it
