Hey guys, been searching the boards but havent come across what im looking for. Im working on a GN that had a performance instruments gnx cluster with autometer gauges installed along with a bunch of other gauges. The speedo does not work and what im looking for is an installation sheet or someone who can tell me if the VSS is wired correctly. This car has a 4 wire VSS that is colour coded green, black, white and red. Everything ive found online so far uses and 3 vss and the caspers vss buffer.
The car is currently wired with the green vss wire to black factory vss optical sensor wire, black vss to green factory vss optical sensor wire, red vss to gauge signal input and the white vss is not being used.
Any hep would be great. thanks,
