My car has been producing a little smoke lately. I pulled the motor and removed the heads since I suspected it was coming from the exhaust guides. Sure enough, lots of burnt oil in the guide area. I didn't put seals on the exhaust valves in fear of melting the guides, a common GN1 issue, hoping the oil would help keep the guide lubricated. Should I put seals on them or do I have a worn guide problem? Are those of you with GN1s using seals on the exhaust valves? Should I have the guides replaced since these are early production heads?
Yes, I'm sure the smoke is from the guides and not from the turbo.
