Last june the seals in my turbo failed. I have since replaced the turbo. When I let the car idle everything seems normal. When I take the car down the block, it starts smoking like mad. What is the problem? I have let the car run for long periods of time to burn off any residual oil that may be in the exhaust system. but after 7 months you would figure that is not the problem. Any help will be great.
After a short run down the street it smokes, when I return home it smokes for a while at idle. I have started it and let it run for about 30 min at a time and it did not smoke. the smoke is kind of grey, it does not smell like coolant and does not really smell of oil.
