Robbie-87plz
Junior Boost-Head
- Feb 12, 2004
...Talked to someone about the 1k-2k stumble...
1. vacuum leak-check with carb cleaner
2. spark plug wire problem?
3. plugs gapped correctly?
4. fuel filter changed?
5. EGR-stick your hand under it when the car is running and push up, if the car dies, it should be good.
Hope that helps...
Hope that helps...
