believe one proIblem I had last year was fuel delivery. Fuel correction varied.I had the Wide Band checked by FAST - ok there.. . Im using a canister type fuel filter by Fram ( gave to me by friend who races non-turbo Car - see photo) and adjustable stk style regulator ( see photo) . Volumn and pressure from the Weldon 2015 may be to much for the components Im using? What can you recomend to use as a filter and regulator in these locations ??? I realize I would need to modify the stk fuel rail - I can handle that. But- I would like to keep the regulator and filter in the same locations. I am changing the return line over from the stk "feed" line to a #6 braided and buying a new battery. Possibly the voltage to the pump was not consistant..I did record the voltage - indicated 14.2 , straght line. However- is it possible the FAST was reading the Voltage from the Alternator and the actual voltage from the battery ( feeding the fuel pump ) was something else? Thanks - Larry
