I'll start by saying I do not know what fuel pump is in my car.The car has a adjustable regulator and complete braided lines.And also a aftermarket guage so I assume some fuel system work has been done.The car had stock inj,and I recentley replaced them with 65 lb,inj,The car started to blow the fuel pump fuse every now and then at WOT.If you drive it easy It's fine.The car doesnt have a hot wire kit and I wonder if the new Inj, are making the pump work harder and causing the problem?Also in the morning the car cranks for a long time then the fuel pressure guage comes up and it starts fine,and will start fine the rest of the day.If it matters the Inj, are high imp, Please any help would be greatly appreaciated.
