I am not sure which way to adjust fuel pressure. Currently it is set at 43 psi with line off. My BLM readings are as follows:
BLM 137 @ idle in nuetral (lean). Idles somewhat rough.
BLM 144 @ idle in gear (lean). Idles somewhat rough.
BLM 124 @ highway cruise (rich).
CC Count 860 @ WOT (rich).
I understand that the 43# injectors I have are calibrated at the fuel pressure I am currently running (43 psi).
Any suggestions for getting more balanced readings? Thanks.
