T talstar New Member Joined Jun 13, 2001 Dec 30, 2005 #1 If you pull the vacum off, should the pressure go up or down? And which way do you set it by on or off?
B Browndog Member Joined Feb 25, 2004 Dec 30, 2005 #2 Pressure should increase when the line is pulled and you set it with the line off.
