my fuel pressure won't go any lower than 42 psi at idle, even with the adjusting screw all the way out and vacuum line on or off. but when the car is driven for about a half hour or more the fuel pressure will drop about 5 psi at idle. anyone else ever have this problem? the regulator is accufab only a couple months old and checked vacuum to reg and its 15". could the return line be blocked? i assume the line going into the reg is the supply and the other is return? sorry for the long post, i'm new to this. any help i can get will be greatly appreciated!
