K here's my problem. Fuel pressure set at 42 at idle. Drops a little when car is started and idling. Have used three different fuel pressure gauges to make sure it's correct. Take car for a drive and after a while pressure increases. 45-50. Cruise around get into a little boost and pressure won't go back to say 39-38. I have used two different fuel pressure reg. no change same thing. Has a walbo pump. If return line was restricted it would be high all the time. Not after driving car. I just blew pressurized air thru the return line for about 3 seconds. It pressurized the tank and I had fuel come out the return line after I stopped the air. I opened gas cap to let air out to stop fuel from coming back out return line. So do you think tank is not vented good enough and after a while it's restricting return flow? Whats confusing is why does this problem happen after it's been running a while and not all the time. any help would be great. Thanks
