BlackoutDrunk
Spring Loaded Idiot
- Jul 30, 2007
Put a new DW pump in my car last week. Today I rolled into the throttle to pass a car and my car fell on it's face. Went lean and when I pulled over and popped the hood I found my fuel pressure was like 20lbs line on. I messed with the fuel pressure regulator and that didn't help much. I shut the car off looked for obvious problems (no fuel leaking and wires look tight) and when I turned it back on the pressure went very high (from me messing the FPR) so I adjusted it back to 42lbs line off and now I'm scratching my head. What could have caused that to happen? Electrical problem? After shutting the car down it holds fuel pressure for awhile.
I have a hot wire kit on the car and when I had the tank down to change the pump everything looked good. The night I changed the pump the car ran great no problems at all.
Ideas?
Ideas?
