Let the car sit overnight, by morning the pressure should be down enough that not much fuel will come out. As for removing the schrader valve a valve stem tool is your friend.
A little trick I learned to stop spewing fuel when removing the schrader valve is to unplug the fuel pump connector by the tank then crank the car over a few times.
