I have a fairly new denso pump and it has been working great. I just started getting knock so I put the fuel pressure gauge back on. I hit about 45 to 48 pounds and then the pressure falls off and the knock goes up. The last time this
happened the fuel line inside the tank split. Is anyone else having problems maybe with too much pressure. Is there anything else I can check before I pull the tank again? What about the adjustable regulator? If so, how do you check it?
