if you are running at 43psi FPR ( Vac line off ) then should be 63 psi so you are right in the ballpark! 1 psi boost should be 1 psi Fuel press rise. ( 1:1 ratio )
how long has the 255 been in there? i just put mine in a couple of weeks ago with the hot w. I'm still at the 13-14 psi stock boost. I really want to baseline what i have before i touch it!
