Hello guys,
Can I please get your input on this matter:
Fuel pressure...when do you typically adjust your fuel pressure?
I'm asking because I thought I had this matter pretty much resolved until I saw the fuel pressure go down once I drove for a while. The car felt a little flatter and I noticed during those instances that my fuel press went down from my previous setting. I mean, as much as 5psi was lost due to heat (warm engine...above 164*), when the cooling fan is running. I also noticed that it dropped once I uncapped the dump tube...Is this normal?
I've been chasing this issue for two days now. For example, during warm ups, it showed.... 46psi Vac off, then after a few blast, fuel pressure changes to about 42/43 vac off. With my car, 2 pounds too much or too little makes a huge difference on my car.
Thanks for your help.
