CONFUSED...
How much hp can the stock lines support before going too lean? My friend is saying run to a single 10 AN line frome the tank to the rail.
1.Will my Walbro be enuff for now to push fuel to hold psi on the factory rail with a 10 AN line? What size return line? Use stock sending line?
2.Should I get bigger rail?
3.Aeromotive 11102 pump?
4.Bigger injectors?
Anyone run 10AN line from the tank to the rail? How much of a pita is it? Do you have a "road map" of the fittings and line? (pics would be a plus) thanks...
4.Bigger injectors?
