Fuel Injector Identification
tim_dogg
Please help me ID this, if more info is needed please let me know.
Pop the connector off the injector. There should be a number stamped into the plastic that will be the injector number.
Not sure of the size, but there appears to be 2 different injectors on that setup: 81271 & 81184
That would be enough for me to pull them out and start wondering . . . . .
hi thanks for the responses guys.
I've googled the numbers and haven't found anything. I'm going to call precision and see if they can look it up from there.
hopefully they are all the same even though the numbers are different haah...
EDIT: I just called precision and they need a part number that can be found by popping the electrical connection off. Does anything have to be done before i pop this connection off like disconnecting the battery?
sorry for the beginner questions haha..
Squeeze the metal wire and pull the connector/tab off. Look for the PN typically engraved in the injector body, and Google that . . . .
Those labels are not the injector part#, those have to do with the flow matching process.
The injector part# on that style injector (Delphi) is on the top shoulder. Here:
I popped the connector off but i don't see a part number?
do i have to actually remove it from the fuel rail lol :cry::cry:...
