Art-87TR said:
......... and the sending units are like 300
I need one also and could not locate one at a 4 parts store/chais.
You can find the fuel tank hanger for the carbureted Regal ($30), but not the one for the EFI Regal.
The parts are not readily interchangebale.
Talked to some outfit (DANG, wish I remembered who) about a year ago in NJ who stated that; "...... the TR float resistor design type is on of the better ones and hardly ever fails". "Usually, they can be fixed by just taking an eraser on the back of a pencil and rub/clean the wires carefully."
So, ........ I pull the tank down again, cleaned and verified adjustment of the float resistor. (Resistance spec was unknown so it was hard to measure and verify. STILL No change.
Next, I replaced the fuel gauge ......... STILL NO change. Cleaned the gauge connectors and made sure the tank ground was in working order …….. STILL NO CHANGE!!!
Frustrated, I called a supplier who makes fuel sending units and spoke to their engineering manager about the float resistor (Don’t remember who either ...... DAMN CRS!
) He stated that; ".... you would need to know the "rise to fall ratio" of the float to know where to even start and was not aware of “anything that would be close” to the TR." Was hoping he would make a few to support this community. Basically ........... no luck
Maybe one of the TR vendors can make one? CASPERS?
