northerngn
Master Monkeywrench
- Oct 8, 2006
I'm out of fuel system and a bout to go to the track...
The car was/is set up to run E-85 and had all the fuel i needed when the motor was stock and using a te45a...
Now i have a fully built motor and a billet 67-65...
The question I have is if i change the fuel energy constant from .680 (E-85) to 1.0 (gasoline) how dead nuts will the tune be after that...
I figured id run out all the E-85 and then refill with c16 or something along that line so that my octane will be there but the fuel volume demands will be less...
Open to ideas...maxxed out at 15lbs of boost and fuel pressure is steady...
Would like to run it around 20 or so...
-Dan
-Dan
