Limit Engineering 6152E turbo freshly rebuilt at limit. The turbo is still in its packaging from limit but i can remove it if anyone wants photos. The exhaust housing has been ceramic coated and its a .63 a/r with the HD actuator. Turbo had zero shaft play before rebuild, it was rebuilt becuse i detected a slight knock in my motor and didnt want to take any chances installing it without having it looked at. $700
TA-49 turbo, low milage, minimal shaft play includes actuator $400
Stock turbo, roughly 80,000miles, some shaft play $100obo
Precision thb3-31 exhaust housing (NEW) $120
AirRide single adjustable Shockwaves, 2 fronts. (NEW) $450
Ingraved chrome plated turbo shield $100
Aeromotive pump speed controller $200
single 2 1/16 gauge pillar pod x2 $15each
2 stock turbo oil feeds and oil return Offers?
Comp 980 Valve springs w/ seals (new) $30
Hotckis tie rod sleeves (new) $45
Caspers Cam sensor cap (new) $50
Caspers Injector harness engine side splice (new) $18
RJC Rocker shaft braces (new) $40
New factory wastegate actuator lines $20
Fuel rail mounted pressure gauge $20
New braided oil feed
Stock intercooler no fin damage. $90
Rockford Fosgate PA-1HD offers?
Wastegate actuator lines with bleed valve boost controller $25
Regulator style boost controller $15
Everything is OBO, you pay shipping and i do take paypal. Any other questions feel free to ask. Thanks, dave
