ahollowtub
- Jun 9, 2006
Selling one of my GN's and my Dodge Ram.I will not seperate the 2.Now for the details:
1987 t top GN
77k orig miles
stock longblock and heads
Comp Cam 206 roller
Rollmaster Chain
Beehive springs
T&D 1.65 roller rockers
Mease 24 row IC
Direct Scan mounted behind glove box
MAFT Pro w/ Pro chip
Limit TA61 Turbo w/ hd acutator
Pats lu 3400 10" stall
Built trans with all hardend parts and fresh rebuild(orig Art Carr trans,no billet parts)
Art Carr Deep trans pan with PTS bottom feeder sump
Innovative WBo2
ATR 3" ss DP
ATR 3" ss exhaust
RJC Power Plate
RJC VC spacers
62mm TB and ported stock plenum
PST steel driveshaft
ATR big rear sway bar
H&R Parts lower control arms
60# inj
all body braces except front lower triangle braces
Nick Micale HD radiator
dual RC fans
braided SS oil lines
Razors alky
Scanmaster 2.1
Full Throttle Speed Hot Wire kit and Walboro 340
rear air bags
external trans cooler
AM boost,VDO egt,and Caspers knock on a pillar
all new AC Delco coil pack/ign mod and ALL sensors
New AC comp kit from Savannah Auto Air
15x6 and 15x8.5 Convo Pro's with new 275/60 MT Drag Radials
T Tops do not leak and ALL mods were done within the last 500 miles and done by an ASE certified mechanic.All bought new and I have receipts for all of it(about $12k worth)I only use AC delco parts(including fuel and oil filters)Alot of parts only have dyno time(cam and such)Southeast Turbo did the cam install.Will also come with ALL stock parts except turbo.Car was all stock when I bought it.Interior is almost perfect with no rips/tears,id say a strong 8.5 out of 10.Car made 334/520@20# and 15d timing so there plenty more left in it.I will also include a p2 IBM Thinkpad with DS and Tuner Pro software already loaded.
Now for the bad:
Car has a 5 ft paint job with some imperfections.1 small spot where the paint is bubbling on the drivers rear 1/4.
cracked horn trim ring
door weather strips are starting to show there age(the ones that are actually attached to the door)
shifter wont pull into 1st(seems like its hanging up in the console)
cracked speaker plate on the top of the dash
older Monroe shocks(still good,just old)
Now for the Dodge:
white 2000 Ram 2500 2wd,5 spd,Quad Cab,LWB
HRVP44 from Industrial Injection
HX35/40 hybrid from forcedinductions.com
Edge 150hp injectors
FASS fuel pump/air seperators
Edge Drag Comp box
K&N FIPK
MBRP 4" SS exhaust and downpipe w/ Banks 5" tip
-8 fuel lines
SBC Con FE clutch w/ upgraded hydraulics
BD short shifter
Centerline wheels w/ new Firestone Transforce HT tires
Piers IC boots
new rotors,pads,brake lines,calipers,rear drums and shoes
3rd gen towing mirrors
Class III receiver hitch
Weathergaurd tool box
100sq ft of sound deadning
Truck has roll up windows and manual locks.Seats are dark grey cloth.Truck made 445/930 on the dyno a few weeks ago.Drives great with plenty of power and will haul damn near anything and still get 20mpg!!All mods have about 10k miles on them and I have about $6500 in parts reciepts.
Now for the bad:
few rock chips in the paint
DS mirror could stand replacing(has a small chip in the plastic and the swivel is a little loose for my taste)
bedliner has a rip in it where an idiot messed it up loading sod
small ding in tailgate
small dent in PS bed above wheel
low speed relay for AC blower motor is out(only works on high)
small crack in windshield
Own the 2 of them for $26k or trade for a 9 second or faster,PROVEN Stage car(GN,WE4,TTA,or T) or a 93 up Supra TT.Im located in Birmingham,AL.Ill post pics up soon.Thanks.
1987 t top GN
77k orig miles
Comp Cam 206 roller
Rollmaster Chain
Beehive springs
Mease 24 row IC
Innovative WBo2
ATR 3" ss DP
ATR 3" ss exhaust
RJC Power Plate
RJC VC spacers
60# inj
dual RC fans
Razors alky
Scanmaster 2.1
rear air bags
Now for the bad:
Now for the Dodge:
Edge Drag Comp box
K&N FIPK
-8 fuel lines
BD short shifter
Piers IC boots
Now for the bad:
